Guest Saul Report post Posted 11/17/2005 12:31 AM Greetings, I'm planning to connect analog lines directly to a D/4PCI card (for CallerID purposes), is it possible to transfer calls to a specific port in the card so we can connect to a PBX extension? Thanks Saul Share this post Link to post
SupportTeam Report post Posted 11/17/2005 12:50 AM Can you please explain in more detail what your proposed setup is and on what lines calls would arrive into the system and then on what lines you want to make outgoing calls (if any). Share this post Link to post
Guest Saul Report post Posted 11/17/2005 02:09 AM I want to use two ports to received calls and the remaining ports on the same card will transfer calls to a PBX or any other combination possible 2-2 or 3-1. Thank you for your prompt response. Saul Share this post Link to post
SupportTeam Report post Posted 11/17/2005 02:57 AM You'll need to do 'Dial and Conference' type transfers with this setup - and to do these you'll also need to use a D/41JCT card. (see: http://www.voiceguide.com/vghelp/html/modXfer.htm) Share this post Link to post
Guest Saul Report post Posted 11/18/2005 01:41 AM Thank you for your help Share this post Link to post
